enable ip-security anomaly-protection ip
enable ip-security anomaly-protection ip { slot [ slot | all ] }
Description
Enables source and destination IP address checking.
Syntax Description
slot Specifies the slot.
all Specifies all IP addresses, or all IP addresses in a particular state.
Default
The default is disabled.
Usage Guidelines
This command enables source and destination IP addresses checking. This checking takes effect for both IPv4 and IPv6 packets. When enabled, the switch drops IPv4/IPv6 packets if its source IP address are the same as the destination IP address. In most cases, the condition of source IP address being the same as the destination IP address indicates a Layer 3 protocol error. (These kind of errors are found in LAND attacks.)
This command was first available in ExtremeXOS 12.0.
Platform Availability
